Hi there, I'm new to the group. I'm in the process of restoring my pas 3x, new power supply, up to date tubes, two new electrolytic caps on the bass controls and new rca jacks along with the resistors. The issue is that the right channel has a buzz. When the volume is turned down, it's more like a buzz-hum, as the volume is raised, the buzz lowers a bit, hum disappears, then becomes louder as the volume is raised. Also, with the left channel, there is less treble when the treble is all the way not being equal with the right channel level. The pot works somewhat because you can here the sweep when the bass is turned down but not as prevalent as the right channel and unfortunately I do like having the option with tome controls. Thanks in advance.
Last edited by Johnyblack on Sun Feb 25, 2024 5:14 pm; edited 1 time in total (Reason for editing : change title)
