    ST70 Voltage Chart
    Bugs
    ST70 Voltage Chart
    Post by Bugs on Mon Dec 20, 2010 1:34 pm
    I took Bob's ST70 Voltage Chart from another post and put into an EXCEL spreadsheet for easier use, however I can't figure out how to attach it as a spreadsheet.
    At any rate, here is an image of the chart. If anyone wants a copy of the original send me an email and I'll get a copy off to you. Please let me know if there are any corrections.
    mantha3
    Values for ST120?
    Post by mantha3 on Mon Dec 20, 2010 1:40 pm
    It would be nice to know what these values are on an ST-120 for my amp...
    Re: ST70 Voltage Chart
    Post by Bob Latino on Mon Dec 20, 2010 2:27 pm
    Below are the voltage readings for the ST-120 amp kit
    GZ34 or solid state rectifier
    Pin 4 to ground – 400 - 425 volts AC
    Pin 6 to ground – 400 - 425 volts AC
    Pin 2 to ground – 490 – 530 volts DC *
    Pin 8 to ground – 490 – 530 volts DC *
    Any 6550/KT88
    Pin 1 to ground – approx .550 volts DC (depends on bias setting)
    Across pins 2 and 7 – 6.0 – 6.5 volts AC
    Pin 3 to ground – 470 - 520 volts DC *
    Pin 4 to ground – 470 - 520 volts DC *
    Pin 5 to ground – minus 50 to minus 62 volts DC
    Pin 6 to ground – minus 50 to minus 62 volts DC
    Pin 8 to ground – approx .550 volts DC (depends on bias setting)
    Quad cap
    Section # 1 (SQUARE symbol) ---------- 480 – 530 volts DC *
    Section # 2 (HALF CIRCLE symbol) ----- 470 – 525 volts DC *
    Section # 3 (NO symbol or CIRCLE) ---- 470 – 525 volts DC *
    Section # 4 (TRANGLE symbol) --------- 400 – 440 volts DC *
    Central 12AT7 – Pin 1 or pin 6 to ground > 130 – 175 volts DC *
    Two outer 12AT7’s – Pin 1 or pin 6 to ground > 255 – 295 volts DC *
    Any 12AT7 – across the two incoming heater wires > 6.0 - 6.5 volts AC
    “-50 VAC” on driver board > 48 – 58 volts AC
    “B+” on driver board > 400 – 440 volts DC *
    * means that the voltage readings will be near the top end of the scale if you use a solid state rectifier
    mantha3
    Post by mantha3 on Tue Dec 21, 2010 8:31 am
    Awsome! Thanks Bob. I printed this out and I'm going to keep a copy in my Amp papers for future reference.
      Current date/time is Wed May 16, 2012 7:40 pm
