    110v or 220v power output.
    kost
    110v or 220v power output. Empty 110v or 220v power output.
    Post by kost Mon Mar 07, 2011 5:20 pm
    Hi to all
    I am about to change the power transformers from both VTA ST 70 and
    st35.
    I live in Greece where we have 220v power and i wonder what is the best solution,
    a 110 v with a step down transformer that i have and it is of a very good quality or a 220v?
    Some people say that its better to have a step down trans,it makes a kind of filtration in power.
    What do you think?
    cheers
    110v or 220v power output. Empty Re: 110v or 220v power output.
    Post by Bob Latino Mon Mar 07, 2011 5:35 pm
    Hi Kost,
    I think it is better to have a 120/220(240) dual primary transformer on an ST-70 rather than run the amp off a 240 to 120 down-drop outboard transformer. Set up like that you can run it at 220 volts but the amp may be easily rewired for 120 volts. If you ever decide to sell the amp it would probably be worth more with a dual primary power transformer. The only downside is that the dual primary PA-521 power transformer for the ST-70 will cost $30 - $40 USD more than the 120 volt version.
    As for your ST-35, Dynakitparts makes 240 volt transformer for the ST-35 - the PB-028-1.
      Current date/time is Sat Apr 27, 2024 9:18 am
