    Dynaco ST-70 Bias problem
    Albert Isaza
    Dynaco ST-70 Bias problem Empty Dynaco ST-70 Bias problem
    Post by Albert Isaza Fri Apr 01, 2011 12:12 pm
    Hi to all, I'm new to this forum.
    Some years ago I purchased an used Dynaco ST-70 kit.
    A few month ago I replaced the old selenium rectifier
    for 1N4007,470uF.100V,10K resistors.
    On the PC-3 installed new resistors,new orange drop 715P/600V capacitors,new sovtek 7199,the EL-34's and the rectifier tube GZ-34 are good.
    The problem I have now is that I can not adjust the
    bias on the left output, the digital meter reads 2.5V
    with the pot turned counterclockwise,if I turn it clockwise the meter gives me more than 3 volts.
    The right output is adjustable to 1.56 or less.
    Voltage test points on can cap A=278V, B=348V, C=418V and
    D=418V.
    I appreciate your help and thanks in advance.
    albert.
    Dynaco ST-70 Bias problem Empty Re: Dynaco ST-70 Bias problem
    Post by Bob Latino Fri Apr 01, 2011 6:06 pm
    Hi Albert,
    A diode has more forward flow voltage than a selenium rectifier so the two 10K resistors on the 7 lug terminal strip must be made a smaller value. What is commonly done is to parallel each of the two 10K resistors with two more 10K resistors effectively giving you two 5K resistors. This should allow you to properly bias your amp again.
      Current date/time is Tue May 07, 2024 9:45 pm
