    VTA ST-70 BOM question
    BruceB
    VTA ST-70 BOM question Empty VTA ST-70 BOM question
    Post by BruceB Mon Mar 23, 2009 8:42 pm
    Finally got around to ordering parts for the board, and got an obsolete/unavailable from Mouser on the six trim pots. Any specific things I should watch out for on a substitute?
    I found some Bourns that are single turn, cermet, 10%, 1/2 watt, blah blah blah... but they are only rated 300V.
    Bruce
    VTA ST-70 BOM question Empty Re: VTA ST-70 BOM question
    Post by Bob Latino Tue Mar 24, 2009 7:51 am
    Bruce,
    If you are using the VTA driver board > the four DC bias controls are Mouser PN 594-63P503. You can use for the 10K AC balance controls Mouser PN 594-63P103T7. These controls see very little voltage - less than 100 volts.
    BruceB
    Post by BruceB Tue Mar 24, 2009 6:28 pm
    In that case, I can use the Bourns pots. They have the top adjust and not the side, which would be pretty interesting to use on the VTA board.
    I ordered this style:
    652-3386R-1-103LF
    Post by Bob Latino Tue Mar 24, 2009 6:55 pm
    Bruce,
    I could be wrong here BUT > I believe you have ordered the wrong part? The Bourns "3386-R" has the pins in a line. I think what you want is the "3386-P" which has the correct triangular shaped pin alignment for the VTA driver board. See photo below.
    VTA ST-70 BOM question VTApot
    BruceB
    Post by BruceB Tue Mar 24, 2009 8:27 pm
    Wouldn't be the first time, lol, and you are so right. I can be creative and make them work until I can replace them.
    I guess it's better to find out now before they arrive (they've already shipped)
    VTA ST-70 BOM question Empty DC bias and AC balance pots for VTA70 PCB
    Post by Roy Mottram Sat Mar 28, 2009 9:27 pm
    the correct part to use is Bourns 3386P or equivilent
    Mouser has them
    652-3386P-1-503LF
    652-3386P-1-103LF
      Current date/time is Sat Apr 27, 2024 1:18 pm
