Someone Emailed me about a "VTA ST-70 amp" that they purchased from a "well reputed tech in Toronto". Well it turns out that the amp is an amp that was built with a new chassis, new power transformer and new driver board but most of the rest of the amp is made up of parts that are original Dynaco. Some other parts are new but they did not come from me. This was sold to a customer as a "VTA ST-70 amp". It is not a VTA ST-70 amp. See below ..
1. There are no triode/pentode ultralinear switches on this amp
2. The amp has Phillips head mounting screws. I use flat head mounting screws
3. The amp uses a VTA ST-70 power transformer but the output transformers are original Dynaco output transformers with TWO screws to hold on the bell covers. The VTA output transformers use FOUR screws per cover to hold on the covers
4. I do not use that type of output binding posts.
5. The choke is a Hammond choke (of good quality). I use Triad chokes
6. They reused the 7 lug terminal strip from an old Dynaco ST-70. The VTA ST-70 uses a 3 lug terminal strip
7. I only use RED hookup wire. The hookup wire used is of different colors on this amp.
8. The tube sockets look to be original Dynaco
See comparison photos of these two amps below ..
Photo of this "counterfeit" amp below ..
Photo of a true VTA ST-70 amp built from a VTA amp kit below ..
