    Switch for VTA-TDR between Tube and SS Rectifier?
    smoorenc
    Switch for VTA-TDR between Tube and SS Rectifier? Empty Switch for VTA-TDR between Tube and SS Rectifier?
    Post by smoorenc Wed Nov 04, 2020 8:50 am
    Hi All,
    First I figured that someone much smarter than me would have done this already. My suspension is that I am about to be told why you can not put a switch in here. I was looking at a way to not have to pull apart the ST-120 when switching rectifiers between tube and solid state. Will this work? I was thinking the power on the back end of the relay will go nowhere once it hit the open end of the switch. What would happen if I did this? Thanks Scott
    Switch for VTA-TDR between Tube and SS Rectifier? Red%20transformer%20switch%20over%20ride-S
    Rbertalotto
    Switch for VTA-TDR between Tube and SS Rectifier? Empty Re: Switch for VTA-TDR between Tube and SS Rectifier?
    Post by Rbertalotto Mon Mar 15, 2021 5:35 pm
    I'd like to do this also....Thanks...Hopefully someone with a higher paygrade than us will answer.
    smoorenc
    Post by smoorenc Mon Mar 15, 2021 6:29 pm
    I did this and it works great. I chatted Bob first and he said it would work. He was right!
    Scott
    Rbertalotto
    Post by Rbertalotto Mon Mar 15, 2021 7:21 pm
    Great...now I have another modification to do....😜
      Current date/time is Fri Nov 22, 2024 1:13 pm
