How to remove fine scratches from the VTA-ST120 chassis?
alexbramford- Posts : 17
Dan W- Admin
You can use metal polish to get the scratches out. Mothers, Blue Magic, Nevr-Dull, or similar will work. I've had better luck with the cream style (Mothers, Blue Magic, etc) vs wadding (Nevr-Dull). If you have something similar in the garage/shed, try it on the bottom cover first to see if you get the result you are looking for.
Dale Stevens likes this post
» My beautiful GZ37 shows some dark/burn on inside glass - but still works fine and the amp biases just fine...
» Refinsh scratches on an SCA-35
» PAS-3 Upgrade
» Plangent Processes - A new way to remove speed variations in master tapes
» NOS Mullard 12au7 Lights up bright inside tube on start up but amp seems to play fine.
» PAS-3 Upgrade
