A quick question: Does the ST-35 Output transformer have the original 8 and 16 Ohms output or is it re-designed for 4 and 8 Ohms?
ST-35 Output Transformer Ohms
jwb474- Posts : 89
- Post n°1
stewdan- Posts : 234
Hi --- in answer to your Transformer Output question, the link below is to Dynaco's Original Transformer Catalog.
http://knob.planet.ee/kirjandus/books/Dynaco_Transformers.pdf
The A-410 Transformer supports EL84/6AQ5. Take a look at the input/output wiring diagram that follows the Transformer Chart.
Stew
Stew
Dave_in_Va- Posts : 446
Re: ST-35 Output Transformer Ohms
I'm guessing the original poster is referring to the VTA ST 35. (The original Dynaco ST 35 had 8 and 16 ohm outputs.)
Roy or Dan should be able to answer this.
jwb474- Posts : 89
Dave_in_Va wrote:I'm guessing the original poster is referring to the VTA ST 35. (The original Dynaco ST 35 had 8 and 16 ohm outputs.)
Yes, I am referring to the VTA offering. I have a SCA project underway and am looking at replacing the Transformers. In the past I have bought from Dynakitparts.com and their offering (Which has been out of stock for over a year) is re-designed to 4 and 8 ohms.
Dan W- Admin
Our current production ST-35 (Z-565) Output transformers have 4 & 8 ohm taps and are in stock.
jwb474 likes this post
