    Power Supply Upgrade for PAS 2 -
    Mr Ridesglide
    Mr Ridesglide
    Power Supply Upgrade for PAS 2 -  Empty Power Supply Upgrade for PAS 2 -
    Post by Mr Ridesglide Wed Jun 19, 2024 9:34 pm
    Sorry, but I didn't want to open a 14 year old thread about Tubes4HiFi making a power supply drop in for my PAS 2. I see Triode sells one either populated or unpopulated. Is there any more that anyone is aware of that I may like more?
    Got my box of goodness from Dan today and getting all excited to get my first ST-70 up and running!
    Game on!
    mark
    10-E-C and FGub like this post
    Post by stewdan Thu Jun 20, 2024 1:38 pm
    Hi --- there are some listings on ebay for "Dynaco Pas Power Supply" PCBs (Raw and Populated).
    Do an Internet Google Search for "Dynaco Pas Power Supply" and see what turns up.
    There should be other PS boards and kits besides Triode.
    Stew
    Mr Ridesglide likes this post
    Power Supply Upgrade for PAS 2 -  Empty Re: Power Supply Upgrade for PAS 2 -
    Post by peterh Thu Jun 20, 2024 2:31 pm
    erhard-audio.com has one called z-psu
    Chart C. Chong had the most beutifil
    I think that there are even more of these with similar functionality.
    Mr Ridesglide
    Mr Ridesglide
    Post by Mr Ridesglide Thu Jun 20, 2024 3:57 pm
    I think erhard is no longer selling as the links all go 404
    Post by peterh Fri Jun 21, 2024 12:26 am
    There is a couple of these boards on ebay
    pas power supply
    The erhard website is ok, the z-psu is here
    z-psu
    Mr Ridesglide
    Mr Ridesglide
    Post by Mr Ridesglide Fri Jun 21, 2024 9:38 am
    Awesome - What I did was buy the Triode board SD Labs - and checked my home inventory for .1uf caps , resistors, diodes. I ended up with $30.00 worth of components from Digikey.
    So I'll be set. I held off on the fuse holder until I see exactly which board arrives, as I've heard there are a couple versions floating around. i ordered 47, 47, 47, 10 as I plan on using the 12x4 for rectification.
    Mr Ridesglide
    Mr Ridesglide
    Post by Mr Ridesglide Tue Jun 25, 2024 8:10 pm
    I got all the parts for this upgrade - and I probably over thought this. I read somewhere that the Rectifier, a 12x4, does not want more than a 10uF cap. So I bought 3 47uF and one 10uF. If using the link below, and seeing the layout of the SD Labs board, which cap should I make the 10uF? I feel like it's C1, but it's just a tad over my head. I think that I got the 10uF in my head from the tube data sheet here: https://frank.pocnet.net/sheets/127/1/12X4.pdf
    board layout here:
    https://oshpark.com/profiles/stokessd/page/2
    Post by peterh Wed Jun 26, 2024 1:37 am
    Mr Ridesglide wrote:I got all the parts for this upgrade - and I probably over thought this. I read somewhere that the Rectifier, a 12x4, does not want more than a 10uF cap. So I bought 3 47uF and one 10uF. If using the link below, and seeing the layout of the SD Labs board, which cap should I make the 10uF? I feel like it's C1, but it's just a tad over my head. I think that I got the 10uF in my head from the tube data sheet here: https://frank.pocnet.net/sheets/127/1/12X4.pdf
    board layout here:
    You read "typical operating.."
    you can safely use the 47uF cap that the kit is built for.
    Mr Ridesglide
    Mr Ridesglide
    Post by Mr Ridesglide Wed Jun 26, 2024 9:34 am
    Thank you Peter - I am still wondering which location is most correct to use the 10uF as I have only three 47uF caps. IIRC, the original has 10,20,20,30 - So I should be able to use it 10,47,47,47.
    Post by peterh Wed Jun 26, 2024 10:08 am
    Mr Ridesglide wrote:Thank you Peter - I am still wondering which location is most correct to use the 10uF as I have only three 47uF caps. IIRC, the original has 10,20,20,30 - So I should be able to use it 10,47,47,47.
    Then put it first. And if disturbing hum occurs order another 47uF ( that's an "if" )
    BTW, PAS is very sensitive to cable routing.
    I have found that when using these power boards the ground and B+ connections can be
    routhed on top of the chassies. Not crossing the board and
    close to the steel on top side, the twisted filements well distanced from the boards.
    Also a jumper between eyelet 1 and 8 on the line board sometimes kills residual hum.
    Mr Ridesglide
    Mr Ridesglide
    Post by Mr Ridesglide Wed Jun 26, 2024 6:06 pm
    Great information Peter! Thank you!
    So, up against chassis it is! I see that mine isn't as organized as some of the others. Perhaps I'll spend some time on that!
    Thank you again Peter.
      Current date/time is Fri Nov 22, 2024 1:18 am
