    Round Two: st-120 Repair Left Rear
    penguinpages
    penguinpages
    Round Two: st-120 Repair Left Rear  Empty Round Two: st-120 Repair Left Rear
    Post by penguinpages Tue Nov 19, 2024 7:59 pm
    Seems I am back again with similar issue:
    https://dynacotubeaudio.forumotion.com/t5069-st-120-debug-repair-left-rear-20vdc
    https://www.dynakitparts.com/shop/metal-film-resistors-1-w/
    1watt 10ohm.
    Burned out again.
    And I think it took out the wire to the digital bias board.
    https://i.servimg.com/u/f48/20/33/91/19/rearri10.png
    And wire .. maybe due to that resistor being dead:
    https://i.servimg.com/u/f48/20/33/91/19/rearri10.jpg
    Questions:
    1) This lasted over a year.  Is this symptom of standard use and wear or more about something else wrong?
    2) If I replace the resistor and cut / resolder wire is this sufficient repair or are there other things to diagnose first?
    As always... thanks for support and input.
      Current date/time is Sat Nov 23, 2024 10:14 pm
