+2
alyosha
6 posters
    ALPS volume control replacement on PAS3
    alyosha
    ALPS volume control replacement on PAS3 Empty ALPS volume control replacement on PAS3
    Post by alyosha Mon Apr 23, 2012 4:34 pm
    I have a question related to the topic title and I hope someone will be able to bring some help.
    I'm trying to change the original PAS3 volume control with an ALPS 'blue' 250k potentiometer while bypassing loudness and can't figure out how to reconnect everything. For info, the ALPS connection tips are numbered 1-2-3.
    Thanks in advance for your replies.
    Best,
    Alyosha
    ALPS volume control replacement on PAS3 Empty Re: ALPS volume control replacement on PAS3
    Post by Roy Mottram Mon Apr 23, 2012 6:57 pm
    there are 3 connections to each half of a stereo volume control (the old ones had a 4th connection for a loudness filter, which isn't needed).
    1 is input, 2 is output, 3 is ground.
    Looking at the front of the control, the left pin is the input, the center pin the output, and the right pin is ground.
    The input will come either from the output of the selector or the output of the balance control, depending on how those are already wired.
    If you haven't taken the original control out, the new one will connect identical, other than the unused connection to the loudness switch, which is just a capacitor to ground and doesn't need to be connected.
    If that explanation doesn't work, you can download the original PAS3 manual and look at the diagrams.
    alyosha
    Post by alyosha Tue Apr 24, 2012 2:24 am
    Hello and thank you so much for your reply. I will try again based on your comments.
    If I understand correctly, my PAS being a factory wired one, should I exactly follow the original diagram? The reason I'm asking is because I saw on a new volume control modification chart that 2 wires should be connected to PC5 n°1, one from lug 1 and another from lug 4 of the volume pot, hence my confusion.
    Thanks again!
    Post by Roy Mottram Tue Apr 24, 2012 11:16 am
    without looking at the exact diagram you are talking about, I can't answer that question. But #1 on the PC5 is ground, so it sounds like your diagram has lugs 1 and 4 of the volume control going to ground, and that is likely correct, especially if the lugs are numbered in reverse order of what I put in my last response (so . . . 1 and 4 are ground, 2 and 5 are outputs, 3 and 6 are inputs?)
    It all depends on which way you look at it . . . . that's why I don't like to use written instructions, they are subject to interpretation.
    Anyone have a photo? A photo is good for one thousand useless words . . . .
    alyosha
    Post by alyosha Tue Apr 24, 2012 12:32 pm
    Hi, mine follows exactly the one on this forum link:
    https://dynacotubeaudio.forumotion.com/t432-pictorial-diagram-for-dynaco-pas3
    Now, what I've found browsing the web and related to #1 on the PC5 is in a pdf document on a site named curcio audio.
    I've tried to rewire everything today based on the original wiring and it still does not work so... any additional input is welcome.
    Thanks again.
    alyosha
    Post by alyosha Wed Apr 25, 2012 6:02 pm
    can't figure it out, I rewired everything based on the original diagram but there is a lot of 'buzz' in the speakers. I placed the alps potentiometer with the connecting pins on the right side (looking at the preamp from the front panel). Could it be an issue of value, 250k being too much? Thanks.
    Post by Roy Mottram Wed Apr 25, 2012 7:17 pm
    can you take a good close up photo of the control and how it's connected?
    alyosha
    Post by alyosha Thu Apr 26, 2012 4:48 am
    Here it is, hope this helps.
    ALPS volume control replacement on PAS3 Dynaco13
    And below is a pic of how it was originally.
    ALPS volume control replacement on PAS3 Dynaco14
    As one of the new vc pins broke, I soldered a different one (green wire on #2 pin). Now, the speaker buzz I mentioned earlier is even more prominent when I touch this very wire while both amp and preamp are on and no source is connected... soldering issue ?
    Thanks again.
    Post by Roy Mottram Thu Apr 26, 2012 11:47 am
    I couldn't make out all the connections from the photo, so I finally gave up and looked at the PAS3 manual, which I hate looking at,
    one thousand words to describe what a diagram shows. See drawing below.
    Make sure all the grounds are connected together and to eyelet 1 on the PC5 board.
    ALPS volume control replacement on PAS3 V-C-PAS3a
    alyosha
    Post by alyosha Thu Apr 26, 2012 12:20 pm
    Thank you so very much for your help and time.
    Just to make sure I do not misread your diagram, based on the alps pin numbers of the first pic I posted (numbers 1-2-3 from bottom to top):
    - all black wires/grounds on 'pin #1 front' including PC5 #1 ?
    - any black wire/ground on 'pin #1 back' of vc pot ?
    Thanks again!
    anbitet66
    anbitet66
    Post by anbitet66 Thu Apr 26, 2012 12:21 pm
    Unless my eyes are playing tricks on me, I think the problem is the original wiring was each row had a black wire (ground) then signal wires. Depending on the row, it was blk, grn, grn; then blk, red, red. The wiring now looks like blk, grn, red in each row. try to put the wires as the above diagram shows from tubes4hifi indicates and the color scheme should return to what it formerly was.
    alyosha
    Post by alyosha Thu Apr 26, 2012 12:46 pm
    Thanks.
    Actually, current wiring from VC is blk-grn-grn (front) then blk-red-red (back). As it is now, 3 black wires are connected :
    - one going from 'pin 1 front' of VC to 'pin 1 back' of bal,
    - one from 'pin 1 front' of VC to pin 1 front of bal,
    - one from pin 1 back of VC to PC5 #1.
    Now, from my reading of tubes4hifi's diagram, it is unclear to me what exactly is connected to pin 1 of VC, front and back.
    Post by Roy Mottram Thu Apr 26, 2012 1:07 pm
    I didn't number my diagram because I was running out of space, but on my drawing it would be numbered from top to bottom,
    1 to 3 on the front section and 4 thru 6 on the rear section
    the original Dynaco drawing is numbered the same, except that the loudness taps are numbered 4 and 8,
    which changes the numbering of the volume control rear section to 5 thru 7 instead of 4 thru 6.
    So, on my diagram he balance control top front #1 and bottom rear #6 are ground,
    and volume control bottom front #3 and bottom rear #6 are grounded.
    Balance #2 goes to volume #1, and balance #5 goes to volume #4.
    All balance and volume controls are wired like this.
    One end is ground, center is output (wiper), and other end is input.
    If I had a PAS3 here I could take a photo for you, it's very very simple.
    OH . . now looking at your photo, I see your ALPS pot is actually labeled 1-2-3 in the reverse order of my drawing.
    On the ALPS, pins 1 and 4 are ground, the inputs are on pins 3 and 6.
    I've got some old photos of ALPS volume/balance pots here: http://tubes4hifi.com/SP8-AM3.htm
    Post by Roy Mottram Thu Apr 26, 2012 1:19 pm
    from your photo and my photo, looks like yours might be wired correctly, but it's hard to see some of your connections.
    I can clearly see that the original pot was wired correctly.
    alyosha
    Post by alyosha Thu Apr 26, 2012 1:40 pm
    which connections can't you see well?
    OK, this is exactly how it is wired now on the alps, using 1-2-3 numbering front and back on the alps and bal from bottom to top (as on posted alps pic):
    2 on PC5 to 2 front on vc (green)
    1 on PC5 to 1 back on vc (black)
    9 on PC5 to 2 back on vc (red)
    3 back of bal to 1 front on vc (black)
    2 back of bal to 3 back on vc (red)
    2 front of bal to 3 front on vc (green)
    3 front of bal to 1 front on vc (black)
    Post by Roy Mottram Thu Apr 26, 2012 2:19 pm
    you've got one of your ground connections on the volume control wired wrong,
    but it also looks like you've swapped channels, the new control should be wired identical to your old control photo,
    where the red wires go to the front section, and the green wires to the rear section.
    you've got:
    2 on PC5 to 2 front on vc (green) should be to #2 on rear section (front is the front panel, rear is closer to rear of preamp)
    1 on PC5 to 1 back on vc (black) should go to #1 on both front and rear sections
    9 on PC5 to 2 back on vc (red) should be to #2 on front section
    3 back of bal to 1 front on vc (black) should be #3 back balance to #3 back of VC
    2 back of bal to 3 back on vc (red) correct, but should be green wire
    3 front of bal to 1 front on vc (black) should be #3 front balance to #1 (both front and rear are ground)
    please, everyone remember, the front and rear sections of balance controls have to be wired opposite to each other to work!!
    input, output, ground on one section, and ground, output, input on other section !!
    alyosha
    Post by alyosha Thu Apr 26, 2012 2:42 pm
    Thank you.
    Actually, after reading your message, it seems that everything is correctly wired except for 1 on PC5 which has to be connected to both front and rear #1 on VC.
    Cheers.
    hawaii.ken
    hawaii.ken
    Post by hawaii.ken Mon Apr 30, 2012 3:24 pm
    alyosha
    Post by alyosha Fri May 25, 2012 4:02 am
    Thank you all very much for your help. It's now working fine, even though the wiring link sent by hawaii.ken is a bit different from the original PAS3 one. Next step will be back RCA panel rewiring with 20awg wire. Thanks again.
    hawaii.ken
    hawaii.ken
    Post by hawaii.ken Fri May 25, 2012 4:17 am
    alyosha wrote:Next step will be back RCA panel rewiring with 20awg wire. Thanks again.
    What kind of wire do you plan to use? Do you have a kit for the back panel?
    alyosha
    Post by alyosha Wed Jun 06, 2012 8:45 am
    well, I was thinking teflon wire, not sure about 20 or 22 awg though. Any recommendation? I have prepared a back panel already.
    Thanks.
    mantha3
    mantha3
    Post by mantha3 Wed Jun 06, 2012 9:36 am
    Make wire
    Buy 22ga 99.9% pure silver wire from http://www.riogrande.com
    http://www.riogrande.com/Product/999-Fine-Silver-Round-Wire-22-Ga-Dead-Soft/105322?pos=1
    Then just buy some heat shrink to go over it. I use this 99.9% to make Interconnects. or better even is the 99.99%. Either is excellent. Use this and you have pretty much as good as it gets. Some of the $300 or more interconnects are just this pure silver dead soft wire. Buy and oz of this and you have about 30 feet of it. use it in the preamp and then make some interconnects.
    http://diyaudioprojects.com/Power/diySilver/
    alyosha
    Post by alyosha Thu Jun 07, 2012 1:37 pm
    Thank you for this 'mantha3'.
    I was thinking of using classic 22awg teflon wire, anyone has an idea where to purchase good quality hookup wire of this kind ? Thanks.
    Luddite
    Luddite
    Post by Luddite Thu Jun 07, 2012 2:31 pm
    alyosha wrote:Thank you for this 'mantha3'.
    Here's a link to Dynakit Parts / teflon insulated wire: http://www.dynakitparts.com/store/product.aspx?id=36 Hope this helps!
    Best Regards,
    Charlie
    Post by Roy Mottram Thu Jun 07, 2012 2:58 pm
    Kevin at DynaKitParts.com has a good price at 50c a foot, as a 100' spool of it runs $39 plus shipping from Mouser.com
      Current date/time is Sun Apr 28, 2024 2:37 am
