Okay, I've inspected this diode's connections.
I've inspected the rectifier tube connections.
I've read the yellow diode sheet.
I's got one question.
There are two lugs on the selenium diode.
The one closest to the chassis has a yellow/black
wire coming from the transformer and is very short.
The lug farthest from the chassis has a black hookup
wire going to the 7 lug terminal strip.
If I want to keep this amp looking closest to stock
and the designer's vision, what is the best way of dealing
with these connections and placing in the new diodes.
Bob himself in a post says to put in a 2 lug strip.
I like this and it would look like it belongs in the amp.
The yellow sheet says to connect the diodes at the
rectifier tube's red wires after changing the positions.
If I connect the diodes to the two red transformer wires
after changing their positions...
What do I do with the selenium diode and its two
wire connections.
I don't think I can just leave the yellow/black transformer
wire hanging and I really don't know what to do about
that other black hookup wire going from the selenium diode
Helpppp
Thanks for reading.
wire connections.
Helpppp
Thanks for reading.
