    ST-70 without a load
    ixe13
    ST-70 without a load Empty ST-70 without a load
    Post by ixe13 Wed Dec 05, 2012 7:29 pm
    Once in a while on ebay you can see a vintage ST-70 on sale, with a bunch of photos.
    More than a few times, though, I've noticed the seller show the amp turned on to show that it's working fine, which is very nice, very upfront to do that, I think,
    Buuuut, the amp in on without speakers connected to it Shocked
    Nothing conneted to the input, nothing connected to the speakers output...
    Obviously, the seller doesn't know much about tube amps I suppose. Isn't it risky to do something like that?
    If the amp is on idle, what are the chance that it could cause some problems?
    Thanx for any thoughts
    Yves
    ST-70 without a load Empty Re: ST-70 without a load
    Post by Bob Latino Wed Dec 05, 2012 8:06 pm
    Personally, I won't turn an ST-70 amp on or any tube amp without a load (the speakers connected). Now in reality, the amp will probably be fine as long as the amp is "on idle" with no music playing. As an aside, I have seen ST-70's that would not bias properly without the speakers connected. One that I recall years ago gave a "cycling bias" with no speaker connected. The bias kept going up and down, up and down above and below the set bias point. When I connected the speakers on this particular amp, the bias settled right down and held steady.
      Current date/time is Fri Apr 26, 2024 8:34 am
