Without much in the way of specs available I am trying to decide what phono preamp to build. I have had a Trancendent Sound GG and phono a few years back and what I have been able to surmise from searching posts that the phono stages here exhibit more of the good tube qualities (warmer). In looking at the PH10 it says warmer than the neutral PH12 but does not give gain. What is the gain of the PH10?
The higher number phono's have output buffers so I imagine they have lower output impedance but can anyone give a spec here or say what is expected for input impedance for best results?
What is required (voltage)for transformers for the different models? The PH10 is differnt requiring less B+ voltage?
I am leaning to building a a 15 but trying to look at all options, I am sticking to MM cartridges at this time but my Soundsmith has pretty low output, are these stages still quiet at 55db gain?
At the present time using a SS Soundsmith pre. It sounds pretty good on on my best LP's but looking for a more forgiving setup that does not highlight every wart and tick on my less than stellar records. A popular phono preamp that I am told that does this is the EAR 834P but I cannot spend that kind of money for what seems to be a very simple design. So that is why I am here? Any help greatly appreciated.
Walt
Walt
