OK...I purchased a VTA st70 board awhile ago that uses 3 12AT7 tubes. Everything is new except for the iron. Just finished putting together. My line voltage is 124. On 5AR4 pin 8 I get 490v. I have a 6.8K resistor between sections 3 & 4 and 1 & 4 have been connected to each other on quad cap. My B+ is good @ 405v but all other voltages are 35-40v high. Is this normal?
Other problem is that there is a noticeable hum or buzz from only one channel. Noise goes away when input jack is in place. Why does this occur and only one channel? Thanks in advance for any info!
