    Shunt Attenuator ok for SP14?
    Avinunca
    Shunt Attenuator ok for SP14? Empty Shunt Attenuator ok for SP14?
    Post by Avinunca Wed Feb 13, 2013 7:27 am
    I want to buy Khozmo stereo shunt attenuator for my VTA SP14 Pre. Can anyone advise if a shunt attenuator will have any adverse effects on this preamp.
    With Shunt working the input resistance varies with different attenuation settings. I would assume that with the phono input fed from my VTA PH15 there shouldn't be an issue as it has a buffer stage at the output.
    Shunt Attenuator ok for SP14? Empty Re: Shunt Attenuator ok for SP14?
    Post by Roy Mottram Wed Feb 13, 2013 2:32 pm
    should not be a problem!
      Current date/time is Fri Apr 26, 2024 10:53 am
