+4
mrconclusion
Corona
WntrMute2
8 posters
    SP 14 Question
    WntrMute2
    WntrMute2
    SP 14 Question Empty SP 14 Question
    Post by WntrMute2 Mon Nov 26, 2012 9:52 pm
    I am considering building the SP 14 kit this winter but I do love the "look" of exposed tubes. They add to the ambiance on a cold winter's night. Anyone build one like thisor have any suggestions as how to accomplish building this preamp so the tubes show?
    Thanks in advance.
    Dave
    Corona
    SP 14 Question Empty Re: SP 14 Question
    Post by Corona Mon Nov 26, 2012 10:23 pm
    Take the top grate off Very Happy
    mrconclusion
    mrconclusion
    Post by mrconclusion Tue Nov 27, 2012 12:09 am
    I don't see any reason why you couldn't do it using the standard chassis. Someone might be able to come up with a reason this isn't a good idea... so wait for the pros to weigh in on this one:
    1. Assemble the circuit board with the tube sockets in their normal position in the front/top side, but install everything else on the back/bottom side.
    2. Decide where you want the tubes to stick through the top to decide where to install the board. The board will be screwed to the underside of the lid, so make sure there's clearance for the transformers, etc. Mark and drill the chassis lid for the board mounting standoffs and then mount the board to the underside of the lid.
    3. Mark the tube socket locations, remove the board, and use a knockout punch to cut holes for the tubes to stand up through the lid. Use a good punch tool to make neat holes in the lid.
    You'd have to use longer runs of some internal wiring to be able to get the lid on and off) but you wouldn't need to open it as often! Also you might try out different standoffs - by shorter or longer ones would make the sockets more or less recessed in the holes.
    I'd just be careful to not reverse the pin order when flipping devices like the transistors from top to bottom of the board, but I can't think of any devices that couldn't be flipped easily. I flipped everything but the resistors on my VTA driver board (to allow for Roy's clear plexi cover) and had no problem.
    Post by Guest Tue Nov 27, 2012 12:16 pm
    Post by Roy Mottram Tue Nov 27, 2012 10:57 pm
    I think one of my customers has built an SP14 like that, but I don't have any photos.
    I know one of my customers in Greece is building an SP9 octal like that.
    It's simply a matter of using a different chassis, just a plain Hammond box, with a custom machined top plate.
    Very easy to do, if you don't want to plan it all out yourself, I can help you do it.
    I'd use a 17" x 10" x 2" Hammond box and it should all fit very nicely!
    mrconclusion
    mrconclusion
    Post by mrconclusion Wed Nov 28, 2012 6:03 pm
    Roy, can you recommend a good source for various chassis/boxes/enclosures? Web searching terms like 'chassis' and 'electronics enclosure' returns a whole lot of irrelevant results!
    Post by Roy Mottram Wed Nov 28, 2012 7:48 pm
    TubesandMore.com and Mouser.com carry almost all of the Hammond line
    Luddite
    Luddite
    Post by Luddite Thu Nov 29, 2012 12:08 pm
    mrconclusion wrote:Roy, can you recommend a good source for various chassis/boxes/enclosures? Web searching terms like 'chassis' and 'electronics enclosure' returns a whole lot of irrelevant results!
    Here's an option I found on Ebay...
    http://www.ebay.com/itm/Deluxe-New-Tube-Amplifier-Preamplifier-Chassis-/290781343373?pt=Vintage_Electronics_R2&hash=item43b3eb2e8d
    Best Regards,
    Charlie
    Post by TMadden Thu Nov 29, 2012 9:35 pm
    Here are pics of a project I am working on, I found the chassis on eBay.SP 14 Question IMG_3018
    SP 14 Question IMG_3016
    goddlediddles
    goddlediddles
    Post by goddlediddles Mon Dec 10, 2012 3:30 pm
    I am building the SP9 and SP6 with the tubes going thru the chassis. It's a Hammond from Mouser, 12" x 10" x 2". The stand-off pillars are just the right height to bring the top of the tube sockets a sixteenth of an inch under the chassis top. Hope the photo is useful. Goddlediddles
    SP 14 Question ChassisTop
    Post by Roy Mottram Mon Dec 10, 2012 10:07 pm
    looks good, time for another beer . . .
    goddlediddles
    goddlediddles
    Post by goddlediddles Tue Dec 11, 2012 2:19 pm
    This shot of the almost finished SP9 build gives a good idea of what it will look like with the tubes going thru the top of the chassis.
    SP 14 Question AlmostFinished2
    WntrMute2
    WntrMute2
    Post by WntrMute2 Thu Oct 31, 2013 10:40 am
    I know I'm resurrecting this thread after almost a year but I was wondering if anyone has had further  pictures of their tube exposed pre-amps?  I don't like the idea of the board being mounted on the top plate as there seems like there'd need to loops of wire inside that could interfere are pick up noise.
    goddlediddles
    goddlediddles
    Post by goddlediddles Thu Oct 31, 2013 11:25 am
    @WntrMute2. Here are the rest of the photos of my project.
    http://www.godfreyryan.com/SP9.html
    gener8r
    gener8r
    Post by gener8r Sun Nov 03, 2013 7:38 pm
    There are units built with tubes that aren't exposed or backlit with colored LEDs???? Say it ain't so!
    http://www.flickr.com/photos/59541088@N08/8606079038/
      Current date/time is Fri Apr 26, 2024 6:13 pm
