    RCA board PAS
    Pillo69
    Pillo69
    RCA board PAS Empty RCA board PAS
    Post by Pillo69 Sun Dec 14, 2014 11:11 am
    Has anyone tried to put RCA gold in the backboard?.
    I've looked measures and space must be greater. Making a CAD drawing board must have 0.260 "more, and have to remove 2 screws from the center.
    Anyone have a better idea?.
    RCA board PAS Board_01
    RCA board PAS Empty Re: RCA board PAS
    Post by Guest Sun Dec 14, 2014 12:33 pm
    Pillo69
    Pillo69
    Post by Pillo69 Mon Dec 15, 2014 7:30 am
    The gold connectors have a larger diameter and retaining nuts are also higher. For placing the separation between connectors must be greater.
    Post by Guest Mon Dec 15, 2014 12:42 pm
    Pillo69
    Pillo69
    Post by Pillo69 Mon Dec 15, 2014 6:15 pm
    About the same as the link (Silver) RCA connectors are the ones I'm using. That size can be used if 9 units.
    I want to use 9 RCA terminals.
    Thank you for your help.
      Current date/time is Fri Apr 26, 2024 5:22 am
