    PA-060 to 220V
    Absent
    PA-060 to 220V Empty PA-060 to 220V
    Post by Absent Sat Feb 06, 2010 11:59 am
    Hi
    Prompt, please, what remake PA060 for functioning from 220V?
    PA-060 to 220V Empty Re: PA-060 to 220V
    Post by Bob Latino Sat Feb 06, 2010 7:05 pm
    Absent wrote:Hi
    There are two things that you can do to allow your Dynaco ST-70 amp to run on 220 volts.
    1. Buy a 220 to 120 volt drop down outboard transformer. This transformer should be capable of delivering 800 to 1000 watts. These are available online at a number of different places for $30 - $40 USD. One such online vendor of these outboard transformers is below.
    220 to 110 or 240 to 120 drop down voltage converters
    2. Purchase a NEW 240 power transformer. If you want a 240 volt transformer then you can buy one from Dynakitparts at the link below.
    PA-521 240 volt power transformer
    Absent
    Post by Absent Wed Feb 17, 2010 3:54 pm
    Thank you.
    Possible hear the amount a whorl for PA-521 (primary and secondary)? and thickness of the package ferric?
    Absent
    Post by Absent Wed Feb 17, 2010 3:55 pm
    if this not secret...
    Post by Bob Latino Wed Feb 17, 2010 4:05 pm
    Absent wrote:Thank you.
    I cannot tell you about the windings because I do not know how they are wound but the iron stack is 2 1/8 inches (about 55 millimeters) thick.
    Absent
    Post by Absent Wed Feb 17, 2010 4:15 pm
      Current date/time is Fri Apr 26, 2024 8:27 am
