    My VTA ST 120 Faceplate
    Tom Pickett
    Tom Pickett
    My VTA ST 120 Faceplate  Empty My VTA ST 120 Faceplate
    Post by Tom Pickett Thu May 06, 2021 12:24 pm
    My 18" x 3/8" x 2 1/2" (L x W x H) aluminum flat bar stock arrived today for my VTA ST 120 faceplate and it looks perfect except of course the length needs to be trimmed to size.
    As you can see in the photos I'm going to have 1 inch overlap on the right and the left of the chassis so I have enough room to install two 2 inch rack handles on both ends of the faceplate for carrying the amplifier when I need to move it to a different location.
    There is 1/4 inch above the bottom of the chassis and 1/4 inch above the top of the chassis which is perfect.
    I'm also thinking about having the faceplate, the quad cap, and the original Dynaco ST 70 mesh metal cover I'm going to install over the VTA driver board  anodized a rose gold color.
    Have a good day and clear skies and stay safe everyone.
    Tom
    My VTA ST 120 Faceplate  775dd910
    My VTA ST 120 Faceplate  Bc0d5c10
    My VTA ST 120 Faceplate  755e2110
    scrotuss
    Post by scrotuss Thu May 06, 2021 1:11 pm
    See photo 2.  Do you plan to incorporate the condiments into your build?
    Tom Pickett likes this post
    scrotuss
    Post by scrotuss Thu May 06, 2021 1:56 pm
    On a serious note- I don't know how you plan to attach the faceplate to the chassis, but I would be hesitant to use the proposed handles to do anything more than slide the amp in and out of a cabinet or tilt it up to get your hands under the center of it in order to carry it.  Once the weight of all that  iron is installed on the rear end of the chassis, you have the possibility of creating some serious torques if you try humping it around with the faceplate mounted handles.  Just my opinion, FWIW.
    My VTA ST 120 Faceplate  Empty Re: My VTA ST 120 Faceplate
    Post by Guest Thu May 06, 2021 3:09 pm
    scrotuss wrote:See photo 2.  Do you plan to incorporate the condiments into your build?
    Tom should relish the opportunity. Very Happy
    DavidR
    DavidR
    Post by DavidR Thu May 06, 2021 4:51 pm
    Have you worked with aluminum before?
    Asking because its a bitch; especially a dremel tool.
    Dale Stevens
    Post by Dale Stevens Thu May 06, 2021 5:06 pm
    Tom, The ST120 weighs exactly 50 lbs stock; Of course that's with music playing thru it ! Dale
    Tom Pickett
    Tom Pickett
    Post by Tom Pickett Thu May 06, 2021 5:35 pm
    Hahaha lol My VTA ST 120 Faceplate  1f602
    Tom Pickett
    Tom Pickett
    Post by Tom Pickett Thu May 06, 2021 5:46 pm
    Dale Stevens wrote:Tom, The ST120 weighs exactly 50 lbs stock; Of course that's with music playing thru it ! Dale
    Dale.... lol
    That's the reason why the faceplate is 3/8" instead of 1/4" lol 😂
    I'm gonna put some heavy duty handles on that extra 1 inch on the outside of the chassis on both sides and they're going to be heavy duty handles enough for me to be able to pick it up or thats my plan. lol
    As for the music playing through the amp making it weigh a little more I'll just make sure that I turn the music and amp off before I move it. That way it should weigh 10 pounds less Hahahahaha 🤣🤣
    Tom
    Tom Pickett
    Tom Pickett
    Post by Tom Pickett Thu May 06, 2021 5:57 pm
    One thing that I did not mention that I want to point out is the backend of the amplifier is really heavy due to the transformers covering almost 1/2 of the chassis on the back. Having that thick 3/8 inch faceplate on the front will help kind of balance the weight out on the front and add some weight on the front that it needs so the weight can be kind of distributed on the chassis frame.
    bobgroger
    Post by bobgroger Fri May 14, 2021 8:39 pm
    The steel used in the VTA chassis is EXTREMELY hard to drill or machine.. I used 3 chinese drill bits to drill a 1/8 inch hole.
      Current date/time is Fri Apr 26, 2024 6:57 am
