Recently have been working on bringing a ST70 and PAS2 back from retirement. (Both purchased in pretty bad condition on eBay).
Did the ST70 first. Very straight forward (on my third one, so it went quickly) Fixed broken speaker connectors, switch and fuse holder (why do these always get smashed, annoying!!). Swapped original PC board for a repop PC3 (7199). New quad cap, bias caps, replaced selenium rectifier. Pulled some good tubes from my stash and voila, instant sweet music.
So, was hoping for a similar quick result for the PAS 2.... Not.
So, here's what I did. Replaced both PC's with Erhard's repops. Installed the Erhard PSU board. Tubes tested well on Jackson tube tester (West German Telefunkens).
Found some initial startup issues. Power switch intermittent, pilot lamp blown, all pots noisy. Replaced power switch, new bulb and cleaned all pots and rotary switches. So... here's where I'm at (took me long enough to get to the problem, eh?)
Right channel sounds fine. Left channel appears to have less gain then the right (have to bias balance towards left to get similar outputs). Audio from left channel seems to have muffled mid-range, and left treble has limited effect (it makes a difference, but not like a working PAS). Preliminary trouble shooting, swapped 12AX7's between channels on the PC-5, swapped the input L/R (to make sure source wasn't the issue) and tried different inputs. Problem is definitely something with the left line stage. (Haven't even gotten to test the phono amp yet).
Not sure where to start, suggestions accepted. My thoughts were to bypass the tone controls. I've seen Curcio's instructions (jumper and disconnects) and Audio Regensis (pretty much the same, but add 1uF cap to prevent DC offset to power amp). Pretty much done working on it tonight, but is that a good first step to track down where the problem is? I'm thinking something is duff in the tone circuit on that side. I don't think there is an issue with the PC5. I did verify all voltages on the board with respect to the PAS2 manual, pretty darn close, so I don't think I muffed up the PSU installation.
Any way, going to step away for a bit, and see what suggestions might come.
Thx
Scott
So..... now I'm
Thx
Scott
So..... now I'm
