by Roy Mottram Sun Feb 03, 2019 8:19 pm
Hi JSL,
surprised no response to this yet. I was gone on vacation a few days.
Most of the answers to this are in the documentation, but let me summarize . . . .
How much time delay does the AB board provide? - red LEDs on for about 20 seconds before ANY bias is applied, then about 40 seconds until bias is ramped up to correct set level.
Is there a specific amount of time (or minimum) delay that is recommended? not sure if you are asking about the auto-bias (preset) or the TDR board (also preset)
How does the time delay board (or AB board) actually keep the onrush of current from the WS1 or WZ68 from reaching the tubes? the output tubes will not conduct current until they have enough bias, about 1 minute
I also understand that if you use the WS1 you should ensure the line voltage doesn't exceed 120v.
I have a variac but sometimes the line voltage floats during a listening session, hardly ever, but it does happen once in a while above 120v.
The basic amp circuit was designed 60+ years ago, when line voltage was around 115v. At 120vac line voltage the B+ is about 25v higher, and at 125vac about 50v higher than design spec.
Using a WS1 or other solid-state rectifier will increase the B+ an additional 20-25vdc above even that amount !! So keep input AC at 115vac or lower !!
Is there is a possibility of damage to the amp if the line voltage raises above 120v for short periods of time if I'm using the WS1? Yes, possible. Most likely damage to the quad cap, not to anything else.
Besides a variac what else can you use to ensure line voltage stays below a specific level? Line conditioners with a REGULATOR are available but are very expensive
Does the WZ68 produce more current than the gz34 tube most definitely, the GZ34 tube is rated at a MAX of 250ma, which exceeds the output current if tubes run at 55ma each.
I personally do NOT recommend using a tube rectifier with KT88 output tubes since they work best with current between 55-70ma each tube or 220-280ma total plus the 25ma needed to run the driver tubes.
A WZ68 is current rated at 450ma. A WS1 is current rated at 1000ma (but it also has an additional 16-17v of output which is NOT needed!)
