PeterCapo wrote:The schematic the tekdevice cap board came with duplicates the original Dynaco circuit. R3 should be 47K. If you put the 10K back, the voltages may come up some, but it still isn't really correct. That circuit is supposed to work with the original values in the original places, as shown in the tekdevice schematic.
All true - but the resistors on-board PC 5 & 6 will handle the differential. I believe that the 10K resistor was a downline modification after introduction.
I did look at mine (installed and all voltages correct). It does have the 10K resistor.
