Since I was doing the critical listening thing, I was hearing the R channel more the the left at times, and the Reverse Stereo mode on the preamp seemed to balance it out. (This seemed to be a preamp issue but it is easier for me to swap the VTA inputs.) Then I got the goofy idea that I would swap L/R inputs to the ST-120, and then the Reverse mode would then be back to Normal Stereo. All was well. Then, I decided it was actually the recordings, not my hearing or equipment. I switched the Amp selector switch to the SS amp to avoid the hum when removing the plugs. With the ST-120 still on, I proceeded to unplug the L/R RCA plugs. Then in a surreal moment there seemed to be more fireworks emitting from my ST-120 than I have seen since Disney World! As quickly as I could, I pulled the plug on the ST-120! The smell of burned electrical components waffed into the silent air.
"You have to be #@%$* kidding me. The amp's right channel died about a year ago! Maybe the same month! July/August... Again, after a serious listening session while being amazed at its magical sound. What the hell am I doing?" Thinking back to this recent incident, I believe I shorted the input of the amp. I fully blame myself. I've unplugged/plugged hot connections to SS gear my entire life without consequence. I guess it just took me a lifetime to realize the danger of what I have been doing. And, this is my first tube amp. A phrase from the movie Forrest Gump has become an earwig in my mind.... I'm still a little stunned. I just love the sound of this amp.
Naturally, the fuse was blown. The tubes showed no signs of distress so I replaced it and powered on. The power tubes began to glow and then went dark. The fuse blew. So I put it on the bench (kitchen island) and took the photographs. I'm stunned. Wow! What did I do? So I will definitely be ordering a new can capacitor, switch, wiring and post. Odd the other components in the burned area seem unscathed. Test, or just replace them? Here are the photos I've taken. https://photos.app.goo.gl/cHG57NFbUgfuKE1NA
