    SCA 35 and 4 ohm speakers
    boycephoto
    Post by boycephoto on Mon Jul 19, 2010 9:13 pm
    A question about the SCA35. I assume the SCA 35 does not have 4 ohm speaker taps because 4 ohm speakers were not common in the early 60's. Other than an impeadance miss-match is the output section strong enough to drive loads rated at 4 ohms?
    Dave
    Re: SCA 35 and 4 ohm speakers
    Post by GP49 on Tue Jul 20, 2010 12:13 am
    You may find the SCA-35 delivering its full power of about 15 watts/channel to a 4Ω loudspeaker because that nominal 4Ω rating is usually a MINIMUM impedance. Across most of the audio band the "4Ω" loudspeaker will have a higher impedance than that. Some vented loudspeakers rated as "4Ω" are at or over 8Ω everyplace but the "saddle" in the impedance curve.
      Current date/time is Wed May 16, 2012 7:38 pm
