    M-125 Build: Binding Posts VERY Close to Power Transformer
    ptstucky
    M-125 Build: Binding Posts VERY Close to Power Transformer Empty M-125 Build: Binding Posts VERY Close to Power Transformer
    Post by ptstucky Sun Jan 03, 2021 7:56 pm
    Hi all,
    I’ve made some progress on my long-shelved M-125 build over the holiday break, but before I continue, I am a little concerned by how close the binding posts have ended up being to the power transformer.  They are not touching, but the middle post in particular is so close that I can just barely slip a piece of paper between it and the transformer.
    Should I be worried about this? I have all the provided spacers/washers installed, but has anyone else had to add a spacer to get a bit more clearance?
    Thanks for any advice on this before I proceed.
    Paul
    Last edited by ptstucky on Sun Jan 03, 2021 8:02 pm; edited 1 time in total (Reason for editing : Could not add photo; removed reference)
    M-125 Build: Binding Posts VERY Close to Power Transformer Empty Re: M-125 Build: Binding Posts VERY Close to Power Transformer
    Post by Bob Latino Sun Jan 03, 2021 8:17 pm
    ptstucky wrote:Hi all,
    Paul
    Hi Paul,
    If you install the backing board on the OUTSIDE of the chassis as instructed, you will have about 3/16 of an inch of space between the end of the speaker post and the power transformer's bottom cover. See photo below.
    M-125 Build: Binding Posts VERY Close to Power Transformer M-125-binding-posts
    ptstucky
    Post by ptstucky Sun Jan 03, 2021 8:51 pm
    Thanks very much for the reply, Bob.
    I do have the backing board on the outside of the chassis, per the instructions, but my results seem to be much less clearance than 3/16". I have a flat washer on the outside (against the backing board), and the flat washer, star washer, and locking nut on the inside on the posts.
    Hopefully the photos below can shed some light on what I might be doing wrong:
    M-125 Build: Binding Posts VERY Close to Power Transformer Img-3515
    M-125 Build: Binding Posts VERY Close to Power Transformer Img-3513
    M-125 Build: Binding Posts VERY Close to Power Transformer Img-3514
    Thanks again for any ideas.
    Best,
    Paul
    Post by Bob Latino Sun Jan 03, 2021 9:42 pm
    Hi Paul,
    Ok - here is what probably happened .. On the M-125's I cut off the "knurl" slot on the end of the binding post to take about 1/8 of an inch off the total length of the binding post. I must have forgotten to do this on your two amps. Note that this cutting off of the knurl does not have to be done on the VTA ST-70 or ST-120 because the binding post is not near then power transformer.
    What I will do is ship you out tomorrow six new binding posts of the correct length. Are you still at the same street address in Washington, DC ?
    ptstucky
    Post by ptstucky Sun Jan 03, 2021 9:56 pm
    Hi, Bob -
    Thanks for the explanation about the knurl end on the binding posts. Very kind of you to send another set, too! (Yes, I am still at the same address.
    I appreciate the continued support.
    Paul
      Current date/time is Tue May 07, 2024 2:16 pm
