    ST70 bias redux
    jeffjmr
    jeffjmr
    ST70 bias redux Empty ST70 bias redux
    Post by jeffjmr Wed Feb 24, 2021 11:15 am
    The sticky on bias recommends .40v for a 40ma current.
    Ignoring tube life for a moment, isn’t this significantly underbiasing? The EL34 data sheet shows a max bias of 150ma and a “typical” bias of 100ma. The old 50ma recommendation was already only half the manufacturer’s recommendation.
    Now I admit I can’t hear the difference but I wonder if a change in distortion can be measured. Theoretically any departure from the ideal bias results in distortion.
    Not being argumentative. Just trying to learn.
    Jeff
    ST70 bias redux Empty Re: ST70 bias redux
    Post by peterh Wed Feb 24, 2021 12:44 pm
    jeffjmr wrote:The sticky on bias recommends .40v for a 40ma current.
    Jeff
    Thet depends on which circuit one uses. In the push-pull amp like ST70 one have 430Volt across the plate <> cathode. The max dissipation is 25W which you get close to with 58mA ( per tube)
    50mA gives 21W 40mA 17W ( which is close to general recommendation)
    In addition to that the rectifier used GZ34 is close to it's maximum current in a ST70, thus not allowing much more then 50mA/tube
    I have measure dist in the interval 40mA to 60mA and the difference was really small, 45mA is a good target.
    jeffjmr
    jeffjmr
    Post by jeffjmr Wed Feb 24, 2021 2:10 pm
    There’s the piece I missed: max dissipation. 21w doesn’t seem excessive given the 25w limit, but I know the output transformer figures in here as well. My ST70 manufacturer recommends 1.00v for the pair (10 ohm bias resistor, 50ma each) but now I understand .800 to .900v might be better advised.
    Thanks for clarifying that for me.
    Jeff
      Current date/time is Sun May 12, 2024 3:06 pm
