    SCA-35 Rebuild
    GSX455
    SCA-35  Rebuild Empty SCA-35 Rebuild
    Post by GSX455 Sun Jan 23, 2022 11:53 am
    I've found this site via Google, and I am new here and new to tube amps.  I have a SCA-35 that I bought.
    It does not power up when I used a Variac to slowly raise power to not ruin the outputs.  I read where you should not operate these without a load, so I hooked up an old pair of speakers.  I checked the fuse in the back looks fine, passed continuity tests.
    When nothing powers up, is this usually the output capacitors?
    Thanks for the help
    ericoto
    SCA-35  Rebuild Empty Re: SCA-35 Rebuild
    Post by ericoto Sun Jan 23, 2022 1:17 pm
    Do the tubes light up at all? Have they been tested? I rebuilt one of these a few years ago, power supplies frequently are not working although an be easily replaced. Look up Tronola on the net, and then Dave's lab he has a written a whole article on restoration of the SCA35 called a 'New look at an old friend" he also sells boards for restoration, I think
    corndog71 and GSX455 like this post
    Post by corndog71 Sun Jan 23, 2022 3:07 pm
    I second that!
    GSX455 likes this post
    GSX455
    Post by GSX455 Sun Jan 23, 2022 9:19 pm
    ericoto,
    The tubes do not light up at all. And I found Dave's lab through other links on this site
    Thank you!
    ericoto
    Post by ericoto Mon Jan 24, 2022 8:23 pm
    If tubes aren't lighting up concerned about power transformer, if you have a voltmeter, check tube heater voltages if OK tubes may be blown
    GSX455
    Post by GSX455 Mon Jan 24, 2022 10:49 pm
    I'm still very new to tube amps, so I check the transformer for shorts, and impedance
    I looked under the board and the wires underneath, the transformer have primary side and a secondary side
    Where do checker the heater voltage?
    Thanks!
    Post by peterh Tue Jan 25, 2022 2:32 am
    GSX455 wrote:I'm still very new to tube amps, so I check the transformer for shorts, and impedance
    Thanks!
    I would recommend a copy of the manual, it's available at this site, look on the "sticky" links
    above.
    With schematics in hand everything is much easier !
      Current date/time is Wed May 08, 2024 6:40 pm
