    IEC panel mount power socket.
    Gabriel
    IEC panel mount power socket. Empty IEC panel mount power socket.
    Post by Gabriel Tue Jan 25, 2022 7:24 am
    Hi
    I’m currently building the ST120 amplifier and would like to utilise an IEC chassis mount power socket for the mains electricity.
    Is there any possible issues with this idea?
    I can’t decide between a female or male panel mount power socket.
    Is there a preferred amp rating for the IEC? Eg 10 amp?
    IEC panel mount power socket. A8c34610
    98indypacer likes this post
    98indypacer
    IEC panel mount power socket. Empty Re: IEC panel mount power socket.
    Post by 98indypacer Tue Jan 25, 2022 10:06 am
    I have an ST120 on pre order and was thinking about doing the same thing. I would think 10amp would be fine. The amp has a 5amp slow blow fuse and I don't think inrush would be an issue.
    The only issue I see is if there is enough clearance between the rear chassis panel and the power transformer.
    IEC panel mount power socket. ST-120%20CCS%20internal%20wiring_600
    Post by peterh Tue Jan 25, 2022 2:47 pm
    See http://n.manet.nu/vta70/ST70-IEC.jpg
    for how it may be done. And yes, i used a IEC connector with built-in fuse.
    Last edited by peterh on Tue Jan 25, 2022 5:41 pm; edited 1 time in total (Reason for editing : Comment about fuse)
    BeerRover and Gabriel like this post
    simpleton
    simpleton
    Post by simpleton Wed Jan 26, 2022 11:10 am
    peterh wrote:See http://n.manet.nu/vta70/ST70-IEC.jpg
    peterh,
    In the image you linked to is shows what appears to be a solid state relay in the lower left. Did you add this in order to add a more accessible power switch?
    I've got a deposit down on a st-120 and planning out just how I want to build it when it comes in.
    simpleton
    IEC panel mount power socket. ST70-IEC
    Last edited by simpleton on Wed Jan 26, 2022 11:11 am; edited 1 time in total (Reason for editing : Holy image size, Batman!)
    Post by peterh Wed Jan 26, 2022 1:47 pm
    The ssr are used for remote power control. 12 volts are tapped from the pre and is used to control
    the SSR. I don't use the power switch.
      Current date/time is Sat Apr 27, 2024 8:08 pm
