    Has anyone made rack-mount M-125's?
    dasa2131
    Has anyone made rack-mount M-125's? Empty Has anyone made rack-mount M-125's?
    Post by dasa2131 Wed Jun 10, 2020 8:00 pm
    Hello!
        About a year and a half ago, I built a rack mount ST-120.  I absolutely love it!  Bob's incredible customer service and technical help were amazing.  Now I've been contemplating building a pair of M-125's to fit on a rack.  Has anyone done this?  Looking over their size, it looks like it would be tight.  Also very heavy.  I'd be making a custom chassis for it.  Ideally, I'd lay out the two amps so that each is a mirror image of the other.
        If you have any thoughts or experience on doing this, please let me know.
    Thank you!
    Dave
    Has anyone made rack-mount M-125's? Rack_p11
    rjpjnk
    Has anyone made rack-mount M-125's? Empty Re: Has anyone made rack-mount M-125's?
    Post by rjpjnk Wed Jun 10, 2020 11:50 pm
    Those power tubes need lots of air flow to get rid of all the heat. Rack mounting seems possible but only with special attention paid to air flow. Items mounted above the tubes may be in danger.
    Post by Bob Latino Thu Jun 11, 2020 7:48 am
    Hi Dave,
    The VTA M-125's are 10 inches wide so two together won't fit side by side in a standard 19 inch wide audio rack. A pair of M-125's does give off a lot of heat and a pair will weigh about 70 pounds. Personally, I don't think that it is a good idea to place both amps in the same rack.
      Current date/time is Wed May 08, 2024 9:48 am
