    VTA-ST120 - speaker terminals question
    alexbramford
    VTA-ST120 - speaker terminals question Empty VTA-ST120 - speaker terminals question
    Post by alexbramford Wed Jun 01, 2022 1:06 pm
    G'Day All
    I am just about to buy Blue Jeans speaker cables with welded connectors for my VTA-ST120 - what size spade terminators should I order that would correctly fit the VTA-ST120 speaker terminals?
    6.5 mm or 9.mm?
    Alex Bramford
    VTA-ST120 - speaker terminals question Empty Re: VTA-ST120 - speaker terminals question
    Post by Bob Latino Wed Jun 01, 2022 2:46 pm
    alexbramford wrote:G'Day All
    6.5 mm or 9.mm?
    Alex Bramford
    Hi Alex,
    Those speaker binding posts on your amp are 4 mm in diameter. If you use a 6.5 mm spade lug, it will fit better onto those speaker binding posts. I am assuming here that the 6.5 mm refers to the space between the two flat sides on the spade lug.
    alexbramford
    Post by alexbramford Wed Jun 01, 2022 8:17 pm
    Thanks for the clarification Bob.- I will then order the 6.5 mm spades to terminate the amplifier end of the cable.
      Current date/time is Sat Apr 27, 2024 5:20 pm
