    Starting the st120 up without speakers
    Starting the st120 up without speakers Empty Starting the st120 up without speakers
    Post by Guest Sun Jul 24, 2022 2:03 pm
    I want to start my amp up to make sure all the tubes are in good order but I no longer have speakers. Is there a safe way to fire up the amp without speakers (like terminating the speaker terminals with resistors).
    Thanks in advance.
    Starting the st120 up without speakers Empty Re: Starting the st120 up without speakers
    Post by peterh Sun Jul 24, 2022 3:54 pm
    jsl1234 wrote:Hi,
    Thanks in advance.
    Don't power on without load !!!
    Or connect 8 ohm resistors of enough power on the output terminals before
    powerin on. ( 10w should do if you are observant on their temp)
    Post by Bob Latino Sun Jul 24, 2022 3:57 pm
    jsl1234 wrote:Hi,
    Thanks in advance.
    Yes - you need some type of "dummy load" on both output transformers. Check out the link below for a relatively inexpensive solution. You will need two of these > one for each channel. These are from China. If you look on Parts Express in the USA, they also have them but they are more expensive.
    Dummy load 8 ohm 100 watt resistors
    Post by Guest Sun Jul 24, 2022 4:02 pm
    Thanks all.
    Post by Guest Sun Jul 24, 2022 4:04 pm
    Thanks all. Should I also null the input?
    Post by Bob Latino Sun Jul 24, 2022 4:26 pm
    jsl1234 wrote:Thanks all. Should I also null the input?
    Yes - Just keep your interconnects plugged in to the amp and your preamp and you will be OK.
    cci1492
    cci1492
    Post by cci1492 Tue Jul 26, 2022 8:14 am
    If you need to have amp powered on without load, shorting the output will protect the amp.
    Tubes4ever likes this post
      Current date/time is Wed May 01, 2024 10:34 pm
