    ST120 with no speakers connected???
    Rbertalotto
    ST120 with no speakers connected??? Empty ST120 with no speakers connected???
    Post by Rbertalotto Sun Nov 20, 2022 10:27 am
    I have a Tubes4HiFi ST120 Tube amplifier I built a couple years ago. I have a number sets of speakers that I like to audition from time to time. It is my understanding that you are not to disconnect speakers from a tube amplifier while it is running or for some time after you have disconnected power or damage will result?
    Can I build a switch box of some type that would put 8ohm resistors on the outputs with the amplifier still on, while I switched speaker leads from one set of speakers to the other.
    If "yes".....What type of switch or circuit would I build for such a device?
    ST120 with no speakers connected??? Empty Re: ST120 with no speakers connected???
    Post by peterh Sun Nov 20, 2022 12:19 pm
    Rbertalotto wrote:I have a Tubes4HiFi ST120 Tube amplifier I built a couple years ago. I have a number sets of speakers that I like to audition from time to time. It is my understanding that you are not to disconnect speakers from a tube amplifier while it is running or for some time after you have disconnected power or damage will result?
    Any switch box that connects the next speaker BEFORE disconnecting the present .
    "Make before break" as they call it.
    NEVER LEAVE OUTPUT OF A TUBE AMP DISCONNECTED !!!
    Rbertalotto
    Post by Rbertalotto Sun Nov 20, 2022 1:24 pm
    I was told that p[utting a 100 ohm resistor across the speaker output terminals would not degrade the sound and would protect the output transformers....??
    Post by peterh Sun Nov 20, 2022 1:30 pm
    Rbertalotto wrote:I was told that p[utting a 100 ohm resistor across the speaker output terminals would not degrade the sound and would protect the output transformers....??
    Yes, this can be seen as an insurance. But i would still never leave the output open. Shorting
    however is no problem for a tubeamp.
    Rbertalotto
    Post by Rbertalotto Sun Nov 20, 2022 1:37 pm
    Thanks! I just ordered two 10w / 100 ohm / 5% wire wound aluminum case resistors.....
      Current date/time is Sun Apr 28, 2024 1:53 am
