    Dynaco paint question
    WLT
    WLT
    Dynaco paint question Empty Dynaco paint question
    Post by WLT Wed Nov 16, 2022 7:50 pm
    The vintage amps have two different cover color paints. The earlier version was a brown and the later a black. I have been able to match the black using several manufacturers of satin black spray paint. i am not finding the proper match for the brown though.
    Can anyone recommend a make/model of spray paint that is a good match for the early brown paint. thanks in advance.
    David1948
    Dynaco paint question Empty Re: Dynaco paint question
    Post by David1948 Thu Nov 17, 2022 3:27 pm
    A post in Feb 2014 said Valspar "Java Brown" is a fairly close match to the older brown Dynaco tube cages. It is also a satin paint with a low gloss.
    Post by Bob Latino Thu Nov 17, 2022 4:27 pm
    David1948 wrote:A post in Feb 2014 said Valspar "Java Brown" is a fairly close match to the older brown Dynaco tube cages. It is also a satin paint with a low gloss.
    Yes - check out the post on "Dynaco brown" at the link below ...
    Dynaco brown color post from 2014
    Read at the link why most Dynaco users think Dynaco chose to change to a "black" paint for the tube cages in the late '60's
    WLT
    WLT
    Post by WLT Thu Nov 17, 2022 8:51 pm
    The Valspar Java Brown is not available in a spray can. Limited sources for quarts as well. It may be discontinued and only stock left is for sale. I may try to buy one of the quartz and add it to my sprayer. Not sure how that will turn out
    Thanks for the help.
    WLT
    WLT
    Post by WLT Mon Nov 21, 2022 5:45 pm
    No luck finding any of the Java Brown. Spray or cans. It looks like they stopped making it and none left to purchase. Any other suggestions?
    David1948
    Post by David1948 Mon Nov 21, 2022 7:51 pm
    Looks like Rustoleum spray paint comes in several shades of brown per the Home Depot website. You might take the cage with you to the paint department and see if one of these matches
      Current date/time is Thu May 02, 2024 6:50 am
