    What causes cathode resistor to blow?
    ChetJettison
    What causes cathode resistor to blow? Empty What causes cathode resistor to blow?
    Post by ChetJettison Mon Dec 12, 2022 7:09 pm
    I had this issue happen before on my ST120 when a tube redplated. Cause? Effect? I couldn't say. But one of the cathode resistors had blown. Replacing it and putting in new tubes (a matched quad of TungSol 6550), the problem hasn't returned.
    Until today! I installed a brand new quad of Gold Lion KT88 tubes, because I missed their fluorescent glow. Seconds after switching the amp on: POP! Another cathode resistor blown.
    What can cause this so immediately after installing new tubes? Could I have a bad tube? Or is it something else?
    mijohn
    What causes cathode resistor to blow? Empty Re: What causes cathode resistor to blow?
    Post by mijohn Mon Dec 12, 2022 11:17 pm
    Is the resistor that's blown on the same socket as before or another one?
    ChetJettison
    Post by ChetJettison Mon Dec 12, 2022 11:19 pm
    Same side, different socket.
    mijohn
    Post by mijohn Mon Dec 12, 2022 11:31 pm
    Well, I think I would replace the resistor and put the Tungsol's back in or try the Gold Lions again on opposite channels to see if the problem is in the tube that blows a resistor if it happens again..
    Post by peterh Tue Dec 13, 2022 2:21 am
    ChetJettison wrote:I had this issue happen before on my ST120 when a tube redplated. Cause? Effect? I couldn't say. But one of the cathode resistors had blown. Replacing it and putting in new tubes (a matched quad of TungSol 6550), the problem hasn't returned.
    Did you turn down the bias adjustment to minimum bias before changing tubes ? If not
    the new tubes might have drawn excessive bias and thus blows the resistor.
    Any powertube changes need bias adjustment, and should start with bias at the minimum.
    Dave_in_Va and 10-E-C like this post
    Dale Stevens
    Post by Dale Stevens Tue Dec 13, 2022 4:54 pm
    Chet, also clean and retention the sockets pins. Different tubes do have small differences in pin diameter. Dale
    Dave_in_Va likes this post
      Current date/time is Sat Apr 27, 2024 11:01 am
