+4
New2Tubez
jwb474
vuejaday
8 posters
looking for volume and selector knobs for dynaco pas2
vuejaday- Posts : 16
jwb474- Posts : 74
Check out this and see if it will meet your needs.
https://www.worthpoint.com/worthopedia/dynaco-dynakit-preamp-amp-nos-knobs-3867732091
vuejaday likes this post
[quote="jwb474"]Check out this and see if it will meet your needs.
thanks, guess i could sign up for a free trial to see how much they are.
odd, i can't quote you using your complete quote!!
New2Tubez- Posts : 184
Have a look here too:
https://www.erhard-audio.com/Accessories_Kits.html
It says not appropriate for original pots but maybe you could mod them? On the good side, it’s a complete set.
I have gotten some on eBay for my PAT4 on occasion.
New2Tubez wrote:Have a look here too:
well again, i can't do a complete quote. this is a weirdly constructed site. but in the end it may be worthwhile.
that site looks close to the dynakit site.
i'll keep searching.
thanks for the info.
"well again, i can't do a complete quote. this is a weirdly constructed site. but in the end it may be worthwhile.
that site looks close to the dynakit site."
You quoted me but I didn't say the above. It says $43 for the set. Silver or black.
Good luck in your search...
jwb474- Posts : 74
vuejaday wrote:jwb474 wrote:Check out this and see if it will meet your needs.
Yes Worthpoint can be a pain to use, but sometimes they have something no others offer.
Dynakit Parts also offer the Black or Silver Knobs. They sell them individually. https://www.dynakitparts.com/shop/control-knobs/
I was hoping the Update My Dynaco would have had the knobs in gold
since they sell the replacement panel in gold and extruded. Mite contact them, he may have some stashed away he could sell. https://www.updatemydynaco.com/storeindex.html#PAS-3X
[quote="jwb474"]
thanks,
the dynakit knobs don't fit the original pots. note that for some reason i have to eliminate your links to reply. weird stuff!
thanks,
jwb474- Posts : 74
thanks,
They do also sell a adapter sleeve to fit the 6mm split splined shaft, CTL-HW-C . https://www.dynakitparts.com/shop/control-hardware/
[quote="jwb474"]thanks,
thanks, that's an option.
jwb474- Posts : 74
A 2-Cent commentary: I do find it frustrating that I cannot easily find the Gold tone knobs for Pas/FM3/SCA or knobs for other Dynaco pieces. The same for front panels.
It would seen that it would not be that more expensive to make a run of aluminum knobs that were gold anodized.
Antique Electronics Supply has a wonderful selection of knobs. I bought from them before for other projects. Odd address for their site: https://www.tubesandmore.com/products/knobs
[quote="jwb474"]A 2-Cent commentary: I do find it frustrating that I cannot easily find the Gold tone knobs for Pas/FM3/SCA or knobs for other Dynaco pieces. The same for front panels.
yea i should check with them. i've used antique/tubesandmore/amplified parts for years.
this eliminating links is getting old.
thanks,
thanks,
vuejaday wrote:jwb474 wrote:A 2-Cent commentary: I do find it frustrating that I cannot easily find the Gold tone knobs for Pas/FM3/SCA or knobs for other Dynaco pieces. The same for front panels.
thanks,
vuejaday > as of 6/18/23 you have only been a member for 3 days .. You have to be a member for 7 days to post links and/or photos. I had to do this because we had a few "new members" join and immediately post spam ads and/or porno links. I then had to delete their junk and kick them off the forum.
Dynaco Tube Audio Forum Moderator
Bob Latino wrote:vuejaday wrote:jwb474 wrote:A 2-Cent commentary: I do find it frustrating that I cannot easily find the Gold tone knobs for Pas/FM3/SCA or knobs for other Dynaco pieces. The same for front panels.
thanks,
thanks bob but i am not doing so. the other members are.
vuejaday > Then what do you mean by "this eliminating links is getting old " ? Maybe I misunderstood what you meant ?
people are gladly providing me with good information and they are providing me with links to possible volume and selector knobs. but when i quote their post and respond or thank them, i have to delete the link to properly respond.Bob Latino wrote:vuejaday > Then what do you mean by "this eliminating links is getting old " ? Maybe I misunderstood what you meant ?
i'll just give up for a few days until my 7 day "new member" status is over and i can be a regular member.
thanks bob,
10-E-C likes this post
Roy Mottram- Admin
just FYI I can supply you with the 8 knobs that I source from TubesAndMore.com 6 small and 2 large, $45 including shipping.
Or buy them direct yourself here . . . https://www.tubesandmore.com/products/knob-aluminum-notched-tip-indicator-set-screw-75-diameter
tubes4hifi wrote:just FYI I can supply you with the 8 knobs that I source from TubesAndMore.com 6 small and 2 large, $45 including shipping.
aren't those the same as dynakit knobs that don't quite fit the pot shaft?
thanks for the info. i will check further.
Roy Mottram- Admin
they may be the same, not sure, but I used to sell dozens of sets of them back when I was doing PAS3 rebuilds, and never had any problems with them not fitting.
These are for 1/4" shafts, and also work fine with the splined shafts on the PAS. They also work on 6mm shafts, which some none-USA equipment has,
but when you shop for knobs, you can NOT use 6mm knobs on 1/4" shafts.
tubes4hifi wrote:they may be the same, not sure, but I used to sell dozens of sets of them back when I was doing PAS3 rebuilds, and never had any problems with them not fitting.
well, sure wish they would work but i don't want to take the chance and have to mail them back.
thanks,
Wotan- Posts : 31
Probably because when you held the camera pointing down the accelerometer got confused and tagged the pic with the wrong orientation. No biggie though.
Are you looking to do a historically accurate restoration, or just looking for some nice gold knobs? Newark still has an enormous selection of knobs:
https://www.newark.com/w/c/fasteners-mechanical/knobs-accessories/knobs/prl/results?ost=knobs
(I've been around here a while, assume I have linking privileges).
I built a PAT-4 and SCA-35, and don't remember anything unusual about the knobs. But that was half a century ago! They have set screws, right? If they're the type that mate with splines on the shaft I can see where finding the right one could be an issue. But you could probably make something fit and function well with a little mechanical ingenuity.
Last edited by Wotan on Wed Jun 28, 2023 9:32 am; edited 1 time in total (Reason for editing : typo)
Wotan- Posts : 31
OP's inverted pic clearly shows set screw holes on all the knobs. I would be perfectly comfortable reaming them out a bit with a drill if I were he. 1/4" = 6.35mm.
levconz- Posts : 8
- Post n°23
Old Stash of PAS 2/3 Knobs
I might have an old stash of PAS 2/3 knobs. They're not perfect if I remember correctly. Give me to the end of today and I'll find them in my attic and post a pic (if they're still there).
thanks,Wotan wrote:tubes4hifi wrote:they may be the same, not sure, but I used to sell dozens of sets of them back when I was doing PAS3 rebuilds, and never had any problems with them not fitting.
thanks, appreciate your search.levconz wrote:I might have an old stash of PAS 2/3 knobs. They're not perfect if I remember correctly. Give me to the end of today and I'll find them in my attic and post a pic (if they're still there).
