    Telefunken Black Diamond ECC82
    Brap
    Brap
    Telefunken Black Diamond ECC82 Empty Telefunken Black Diamond ECC82
    Post by Brap Sat Nov 25, 2023 8:46 pm
    Decided to try this as my center driver tube, using RCA clear tops for the inverters. Previous center was an Amperex or RCA clear top. What a treat! The low end has opened up more and am more amazed at my Fritz Carerra BE's. Imaging is tad better, soundstage has expanded between the instruments on a macro level. Very clear top and mids but not much different thant the clear top center driver. If you want to roll drivers, I highly recomend giving the Black Diamond a try.
    Big Harry
    Telefunken Black Diamond ECC82 Empty Re: Telefunken Black Diamond ECC82
    Post by Big Harry Thu Nov 30, 2023 9:25 am
    I'm using Telefunken smooth plate 12AU7/ECC82's in the center position of VTA boards in both of my ST70's and to my hearing, they do make a difference.
    Dale Stevens
    Post by Dale Stevens Thu Nov 30, 2023 7:08 pm
    Sounds great. Where did you folks get the tubes. Thx, Dale
    Big Harry
    Post by Big Harry Fri Dec 01, 2023 8:59 am
    I've been buying tubes for more years than I care to remember from closed repair shops and buying old audio and test equipment just for the tubes. Manufactures like Tektronics, Heathkit Eico etc. used Telefunken, Mullard and Amperex tubes in their equipment in the 50's and 60"s because they were sometimes cheaper than the American made tubes.
    Brap
    Brap
    Post by Brap Fri Dec 01, 2023 9:35 am
    Purchased from Tube Depot
      Current date/time is Mon May 06, 2024 6:26 pm
