Hi, I have a Dynaco Dynakit Mark III amp with weak and unmatched 6550 output tubes.
At the moment I can't get here a pair of new 6550 / KT88, but I have a new pair of EL34.
So I would like to use it as mark ii.
I tried to change the resistor that connecting the bias pot to ground from 18K to 7K7 and took some measurements on the amp. Without output tubes the palate voltage is 520V. With -50V at the wiper of the bias pot the plate voltage is 470V but the EL34 draws only 10mA so the bias seems to be too cold. For a higher plate dissipation value I was needed to reduce the bias voltage at the wiper to -30V and the plate voltage was 370V and the tubes draw 48mA which is 17.76W or 70% of 25W.
Does it seems to be normal? or maybe this amp designed to run on cooler bias and 70% is too much for it?
