    Need Output xfmr feet for Mk III
    Greg_M
    Greg_M
    Need Output xfmr feet for Mk III Empty Need Output xfmr feet for Mk III
    Post by Greg_M Wed Nov 10, 2010 11:08 am
    I bought a Sunn 200S which uses (directly) a Mk III (repackaged) as an amp. From all the moving the output transformer's feet have broken off (before I got it). These are the kind that are "L" brackets that slide up underneath the bell covers. Some of the output xfmrs had the feet built into the bell covers. Either would be fine with me.
    If you have a blown output xfmr and would like to give up those covers or L brackets please contact me.
    Luddite
    Luddite
    Need Output xfmr feet for Mk III Empty Re: Need Output xfmr feet for Mk III
    Post by Luddite Wed Nov 10, 2010 11:47 am
    Greg_M wrote:I bought a Sunn 200S which uses (directly) a Mk III (repackaged) as an amp. From all the moving the output transformer's feet have broken off (before I got it). These are the kind that are "L" brackets that slide up underneath the bell covers. Some of the output xfmrs had the feet built into the bell covers. Either would be fine with me.
    Greg,
    If all else fails, you can probably find some flat steel barstock at your local hardware supply. Cut it to length based on the old piece, layout and drill the mounting holes, then bend the "foot" to 90 degrees. Voila! Hint: using a triangular file, scribe a line perpendicular to the bar where the bend is to be made (depth should be about 25-30% of the bar thickness, no more). Bend the bar in a vise with the scribed line on the inside of the bend.
    Best Regards,
    Charlie
    P.S. Assuming you are planning to continue using this as a guitar amp, I recommend replacing the "L" brackets rather than the bell covers with feet. The "L" brackets are much more secure for transporting the amp.
    Greg_M
    Greg_M
    Post by Greg_M Wed Nov 10, 2010 11:55 am
    Yep, I could make them, but it would be more desirable to not have to.... Wink
      Current date/time is Tue May 07, 2024 4:13 pm
