    VTA PAS 2 - Z Mod - (DIY Newbie Question)
    Dingojazz
    VTA  PAS 2 - Z Mod - (DIY Newbie Question) Empty VTA PAS 2 - Z Mod - (DIY Newbie Question)
    Post by Dingojazz Wed Jan 12, 2011 2:12 pm
    I am adding the Z upgrade to my PAS phono section, which already has the VTA Power Supply upgrade, as well as the the VTA "dyna-clone" phono and line stage boards. I have assembled the Z-mod phono board per the instruction, my question has to do with making the Filament Voltage and B+ connections to the Z-Mod board. Currently it appears the Filament voltage connections go to connections 14 & 15 on the "old" phono board. Assuming these are the - and + filament wires, how do I determine polarity?
    Also, it appears (?) that the B+ connect on PC 6 are at 4 and 11... if so, again how to determine polarity there?
    Any help appreciated.
    K.
    VTA  PAS 2 - Z Mod - (DIY Newbie Question) Empty Re: VTA PAS 2 - Z Mod - (DIY Newbie Question)
    Post by Roy Mottram Thu Jan 13, 2011 2:33 pm
    on the phono board, eyelets 4 and 11 are both ground, eyelet 16 is B+
    If you don't have the original schematic for the PAS3 you can download the entire manual here for free:
    http://www.tubes4hifi.com/Dynaco%20PAS-3%20manual.pdf
    Post by Roy Mottram Thu Jan 13, 2011 2:58 pm
    the Zmod boards show polarity because they are also used in the Z preamp (which replaces the older SP8) with a regulated power supply.
    I'll try to post those board diagrams here, if they don't work they are also posted on my website at:
    www.tubes4hifi.com/ZP.htm
    VTA  PAS 2 - Z Mod - (DIY Newbie Question) Vta-pc6
    VTA  PAS 2 - Z Mod - (DIY Newbie Question) Vta-pc5
    VTA  PAS 2 - Z Mod - (DIY Newbie Question) VTA-PAS3-PS
    Post by Roy Mottram Fri Jan 14, 2011 3:15 pm
    I just posted an update to the power supply layout showing where the filament outputs go.
    The final answer to any question is ALWAYs found in reading the schematic !!
      Current date/time is Sat Apr 27, 2024 10:17 am
