    Audio Splitter (Bad for ST-120?)
    mantha3
    mantha3
    Audio Splitter (Bad for ST-120?) Empty Audio Splitter (Bad for ST-120?)
    Post by mantha3 Mon Feb 14, 2011 11:08 am
    I have one of Bobs ST-120 tube amps.
    I run the amp to some nice 3 way speakers and the sound is great. I run my CD player right into my amp and control the volume with the 21 stepped attenuator.
    I have a nice powered sub woofer that also has a volume control. I would like to try running the powered sub with my tube system. To do it easy I was thinking of getting some Audio Splitter RCA cables (photo below). I'd run the splitter off the CD player.. Then run a set of RCAs from the splitter to the ST120 and another set of RCAs from the splitter to the sub.
    Question I had.. Having the RCA signal split.. Will the signal be weaker to the ST120 and will it harm the sound or amp?
    Photobucket
    Audio Splitter (Bad for ST-120?) Empty Re: Audio Splitter (Bad for ST-120?)
    Post by Bob Latino Mon Feb 14, 2011 1:33 pm
    Just running the signal through a splitter won't really alter the signal at all - it won't get weaker. You will just have the same signal now coming out of two female RCA's instead of one. No harm will come to the ST-120.
    mantha3
    mantha3
    Post by mantha3 Mon Feb 14, 2011 3:24 pm
    Cool, I figured it was not a problem. I'm just running the sub as a test try for the heck of it. Not sure I'll use it long term. Thanks Bob!
      Current date/time is Mon May 06, 2024 9:08 pm
