    Bypass filter switch Pas-3
    lobby
    Bypass filter switch Pas-3 Empty Bypass filter switch Pas-3
    Post by lobby Thu May 05, 2011 2:47 pm
    Hello, I have tried to search for an explanation of how to by bypass the filter switche on the pas 3, but cannot find it. I just got done replacing the rectifier and quad caps with a new PBC, replaced a few caps on the PC-5, as well as bypassed the tone controls when I was in there, but now I would like to bypass the filter switch too. If anyone can link me to an explanation or describe how, it would be greatly appreciated. Also, is there anything else I should take care of while I have her opened up?
    Bypass filter switch Pas-3 Empty Re: Bypass filter switch Pas-3
    Post by Roy Mottram Thu May 05, 2011 11:25 pm
    have you looked at the schematic? you don't need to bypass anything, just remove the switch.
    All the switch does is bypass a resistor to the hi freqs roll off. Take the switch out and all is good.
    lobby
    Post by lobby Fri May 06, 2011 1:00 am
    I unfortunately cannot read schematics. One day I will take the time to learn.
    So I just need to remove all wires and the resistors going to the switch and it will be okay?
    Post by Roy Mottram Fri May 06, 2011 1:02 am
    yes, just remove the wires and resistors that are connected to the switch, and you'll be all set
      Current date/time is Thu May 02, 2024 8:58 am
