Is it OK to bypass the Selenium like this?
peterh- Posts : 1833
The cap seems old.
Using the Se as tiepoint may be ok, but i would recommend a kit with caps solder tag and diode. dynakitparts.com has it. You can continue to use the amp until the parts arrives.
bubbasweet- Posts : 95
I did the cap was just asking about bypassing the selenium.. I read where when they fail they go high resistance so the diode bypassing is OK.
That is my question. Is there a reason electronically why not to do this? Cap has been replaced THX..
Yes there is. A short in the Se, although very rare, will kill your bias. Eliminating a possible source of failure reduces risk of problems .bubbasweet wrote:I did the cap was just asking about bypassing the selenium.. I read where when they fail they go high resistance so the diode bypassing is OK.
In addition to adding the diode you most likely need to adjust the resistors to compensate for the reduced voltage loss. This to make the bias adjustment pot have a reasonable adjustment range.
Pots and achieving Proper 1.56V range seemed not a problem with room to move even with the original 1K Resistor. I think I have a few Terminal strips and remove the selenium rectifiers.
danielrhall- Posts : 4
- Post n°6
Use only one SR tab as a tie point
[Repeating my reply from the AK forum...]
If you want to leave the selenium rectifier in place for nostalgic purposes, I'd have no qualms about using one of its tabs for a tie point (I did the same with my Dynaco ST-70) but I wouldn't use both tabs, especially the way that diode and SR are electrically in parallel.
