    Unknown ST-70 Circuit Board
    Sal
    Sal
    Unknown ST-70 Circuit Board Empty Unknown ST-70 Circuit Board
    Post by Sal Wed Jul 27, 2011 10:02 pm
    Does anyone know anything about this circuit board installed on a ST-70 I have in for repair. The ST-70 works but the volume is lower than usual. Voltages and Bias is OK. The tubes are 12BH7's. The feedback lines from the 16 ohm taps are not connected to the board.
    If you have any documentation for this board, please let me know.
    Sal
    Unknown ST-70 Circuit Board Toppbc
    Unknown ST-70 Circuit Board Bottompcb
    Unknown ST-70 Circuit Board Empty Re: Unknown ST-70 Circuit Board
    Post by stewdan Wed Jul 27, 2011 11:54 pm
    Hi Sal --
    Your board was made and marketed by Purist Audio Design in Clute Texas (near Lake Jackson), about 25 miles from Houston, Texas. There was an issue of Glass Audio (early 90's) were Roy Mottram reviewed the replacement boards that were available at the time. The PAD 70 was one of them.
    I bought 2 of the boards for the ST70's that I had and installed them, I thought that they sounded very clean and nice. The version of the boards that I bought used a 12AX7 for each channel, not the 12BH7.
    Oh, the Pad Board does not use the Negative Feedback from the Output Xformer.
    I have documentation for my version of the board if that would help?
    Schematic and Bottom Traces and hookup points.
    If you have a fax, I can fax the sheets to you.
    Let me know,
    Stew
    Sal
    Sal
    Post by Sal Thu Jul 28, 2011 12:06 am
    Hi Stew,
    Thank you for your information, I knew someone out there seen this board. I don't have a fax machine as mine broke but my brother has one. I will pm you tomorrow with his fax number as I am not sure of it.
    I wonder if the wrong tubes were installed. I can check you schematic to see if I have the same board.
    Thanks again,
    Sal
    Post by stewdan Thu Jul 28, 2011 7:01 am
    Hi Sal --
    After I replied to your post, I compared the solder trace side in your picture with my solder trace hardcopy and it is indeed the same PCB.
    The large capacitor and the resistor that are on the bottom of your PCB picture are mods against the original PCB. Probably to handle the 12BH7??
    Anyway, let me know the fax number and I will send you the hardcopy.
    Stew
    Sal
    Sal
    Post by Sal Thu Jul 28, 2011 12:49 pm
    Stew,
    I sent you a PM with a fax number.
    Sal
    Post by stewdan Thu Jul 28, 2011 2:54 pm
    Hi Sal --
    I faxed you 8 pages (cover page and what I had for the PAD70.)
    Page 1 - Cover
    Page 2 - Schematic
    Page 3 - Figure 3 - Solder side of PCB with labels
    Page 4 - Figure 2 - PAD70 hookup to ST70
    Page 5 - Stock Dynaco Quad Cap Hookup Diagram for PAD70
    Page 6-8 - PAD70 Instructions that I got with the PCB (has voltage readings for the 12ax7 circuit)
    If anything is missing or unreadable, let me know and I will resend the item.
    As I said in an earlier post, the large 100MF Capacitor that is wired to the solder trace side of the PCB is not standard fare for the PAD70.
    Hope this helps!!
    Stew
    Sal
    Sal
    Post by Sal Thu Jul 28, 2011 7:14 pm
    Thanks again Stew,
    I will pass by my brothers house tomorrow and pick up the fax's you sent. I will pm you later in the evening.
    Regards,
    Sal
    Sal
    Sal
    Post by Sal Fri Jul 29, 2011 8:21 pm
    Stew,
    I just picked up the faxes from my brother, thank you! They are very readable. The board installed in the ST-70 has 4 bias bots and 2 others which I don't see on the schematic. I will have to trace it out.
    Thanks again,
    Sal
    Sal
    Sal
    Post by Sal Mon Aug 01, 2011 9:37 pm
    Stew,
    I replaced the 12BH7 tubes with 12AX7 tubes and the volume doubled! Tht amplification factor between the 12BH7 tubes vs. 12AX7's are more than 5 to 1! 16.5 vs. 100..
    Thanks again,
    Sal
    fatso
    Unknown ST-70 Circuit Board Empty same as Mark 3's
    Post by fatso Mon Feb 12, 2018 4:56 pm
    Hi Everybody
    purist audio design (PAD) also made this circuit for the Dyna mark III's. i had it and it was great.
    it is supposedly a spin on a low-ball guitar amp driver, but whatever Jim at PAD tweaked it to, did wonders - - - maybe it was just the short signal path and good associated stuff that i had in my MK III's... but i'd like to resurrect it again and i sold them off over a dozen years ago
    any of the schematics, ultralinear connections, bias resistor values, etc would be greatly appreciated!!!! even a circuit board diagram
    thanks
    fatso
    Post by stewdan Wed Feb 14, 2018 2:20 pm
    Fatso ---- the material that I sent to Sal in 2011 is still available, if you want it.
    Faxing it would be the only way that I can sent it.
    Let me know,
    Stew
    Post by Roy Wed Feb 14, 2018 3:12 pm
    * https://www.lifewire.com/free-fax-services-2378048 could be handy for those without access to a fax *
      Current date/time is Thu May 02, 2024 4:22 am
