by Guest Tue Dec 18, 2018 8:47 pm
ericoto wrote:That fixes it, it is again loud and clear. Sounds great. When I purchased I did not recive instruction for the first parting setting the unit. One amp doesn't bias well, Voltage on C13 lower than voltages on tubes pin 1. Could the issue be not setting to a reference? How can I do that now that hey are installed?
The following is to set the bias for the output tubes once the AB pcb has been installed and wired up to an amp. It may not be the solution to your particular issue, but it is still worth while to go through this process just to make sure both amps are set up the same!
power down your amp and let the power supply caps discharge. Remove all tubes, including the rectifier tube.
Power the amp back up and you should see the small RED LED on the AB pcb light up. It will go off after about 10-15 seconds. Now, set your voltmeter to read no more than 2V or similar, put the black lead on a GND pad on the AB pcb and the red meter lead on the test pad next to the electro capacitor which itself is next to the blue trimmer, see below.
Now adjust that blue trimmer to read say 0.500V or 500mV, which is a good setting for the KT120. You can go as high as 600mV, but that will shorten the tube life. I found 500 to 525mV is a good value.
Once adjusted, power down your amp. Re install all the tubes, power it back up, that small RED LED will go on first then go off after about 10s or so and after about 40-50s all four small BLUE LED's should go on indicating that bias is good for all four output tubes. You're done!
I would do the same process with both amps, set them both to the same 500 or 525mV.
