deepee - "I would keep a daily check on the bias. It'll reach its peak after about 20 minutes. "
If the AB is working correctly then measuring the cathode voltages under no signal conditions will show no difference once the system is up to working temp and the AB is in closed loop. Mine stabilises within 1 minute of coming to life.
Where you may see changes would be in the grid voltages on the respective output valves. This is perfectly normal and will depend upon may factors including line voltage, rectifier efficiency, and the OP valve physical charateristics.
For example here are some readings I took on my amp when I installed the AB board.
Line voltage 244V
5AR4 - VHT 509V
Vg 1 -59V
Vg 2 -59V
Vg 3 -60V
Vg 4 -63V
SS Rectifier - VHT 540V
Vg 1 -64V
Vg 2 -64V
Vg 3 -65V
Vg 4 -68V
In all the above cases the cathode voltage was a constant 0.5V and the raw unregulated bias supply read -73.4V after the rectifier.
Line voltage 244V
5AR4 - VHT 509V
Vg 1 -59V
Vg 2 -59V
Vg 3 -60V
Vg 4 -63V
Vg 1 -64V
Vg 2 -64V
Vg 3 -65V
Vg 4 -68V
