by Guest Sun Apr 07, 2019 1:20 pm
perhaps we need to be careful here in just blaming the auto bias per se.
Yes, it is unusual that you've had such failures, but we need to hear from others as well to see if they've had any issues, as well as from Roy if he's had any negative feedback.
Also, Pavel, have you heard any such issues?
Again, I've had zero failures in the ones that I have installed in my builds.
One interesting point to consider and perhaps Pavel can chime in here. I use a separate mini 9VAC transformer to power the auto bias modules as my 6.3VAC winding are referenced to ground via a pair of 100R resistors to eliminate hum, that is, one 100R resistor from each end of the 6.3VAC winding to ground, since my custom power transformers do not have a center tap in their 6.3VAC windings.
Now, the Dynaco PA060 does have center taps on the 6.3VAC winding and these are tied to ground via a 0.022uF cap each. Does this in ANY way cause an issue with the auto bias module.
