It sounds the same as it does when connected to the ground lug of the phono preamp.
There should be NOTHING connected to phono pre-amp ground lug. It should not even be there.
Please describe exactly what you have done.
thermionicvinyl wrote:
I used "Adobe audition" to record and analyze the noise. It's an Asus Xonar sound card connected to a laptop, with which I then record the output via an RCA to 3.5mm jack cable. The recording is then analyzed after the fact. I'm pretty sure if you want RTA you'd have to use REW.
