    Trigger relay add needed to turn on power of ST-120 from my pre-amp
    smoorenc
    Trigger relay add needed to turn on power of ST-120 from my pre-amp Empty Trigger relay add needed to turn on power of ST-120 from my pre-amp
    Post by smoorenc Tue Nov 24, 2020 11:14 pm
    Hi, I saw somewhere on here a small relay circuit board and mini jack to wire output. This was so that the trigger voltage output from my preamp could power on my new St-120 , like it did my original PS Audio SS amp. I am searching but now I am unable to find that post. Can someone show me what I need please. It would be appreciated. Thanks! Scott
    Trigger relay add needed to turn on power of ST-120 from my pre-amp Empty Re: Trigger relay add needed to turn on power of ST-120 from my pre-amp
    Post by peterh Wed Nov 25, 2020 3:58 am
    smoorenc wrote:Hi, I saw somewhere on here a small relay circuit board and mini jack to wire output. This was so that the trigger voltage output from my preamp could power on my new St-120 , like it did my original PS Audio SS amp. I am searching but now I am unable to find that post. Can someone show me what I need please. It would be appreciated. Thanks! Scott
    This is what you need :
    https://www.mouser.se/ProductDetail/Crydom/LND4450C?qs=xZ%2FP%252Ba9zWqYUASw9UR3BIQ%3D%3D
    It may be installed inside the amp, connected in parallell with the circuit breaker and
    with a connector for the trigger signal.
    The really good thing with these is that they break and make in the zero crossing of AC,
    thus eliminating most of the sharp "bangs" that a conventional relay creates.
    smoorenc
    Post by smoorenc Wed Nov 25, 2020 7:57 am
    Thanks! It is a very nice looking relay!
    smoorenc
    Post by smoorenc Sat Dec 12, 2020 8:09 am
    [/quote]
    Thanks! It is a very nice looking relay![/quote]
    It all worked like a champ! I Got a Crydom LND2425 relay and a MJ-3502 female jack from Mouser. I mounted to the rear. The relay fit "sandwiched" between the main transformer and the bottom of the chassey perfectly. Thanks!
      Current date/time is Tue Nov 26, 2024 6:06 am
